Which ecu?
20136.7
The 6.7 powerstroke uses the same ecu as the 2011 and up duramaxes does it not? Is so why doesn't efi live support the fords?
Jomax
Arizona
You lost me there. First I've heard of that.
SpartanDieselTech
They share the same Bosch architecture, but that's as far as it goes. Operating system is different, application software is different. Different number of actuator outputs and drivers. Not interchanegable in the least; the only caveat to that being that a good understanding of Bosch control logic will help with calibrating both.
Oroville, CA
Could EFILive support them if they wanted to? Very much yes.
drunk on diesel
but... it's not basically the same ECU :confused:
in the broad sense that it controls a diesel engine and is made by the same manufacturer? ok... but at that point, ALL current diesel ECU's are "basically the same"
