Which oil cooler?
tannerbutler2253
Just put a egr ****** kit in my 6.0 and I'm gonna put a new oil cooler on to. While one do you recommend getting? Stock ford? Or an aftermarket? If aftermarket which one?
Sent from my SM-G920V using Tapatalk
slc6oh
Utah
ford/maxxforce oil cooler. no if' ands or buts. my ebay special one **** the mount o ring after 3 months and was leaking oil. ( should have known better )
replaced with factory oil cooler, cut the ebay one and a clogged oem one I had sitting on the bench, and had a dorman one sitting there as well. cut them all open with a band saw.
the ford/maxxforce one looks waaaay better inside. more uniform. even had more rows in it .
the dorman one looked worse than the ebay one.
slc6oh
Utah
my delts t's were good with the china/ebay special one, but are even better with the fold one. average 3-6 degree split. with china was like 6-10
Kbuterbaugh04
I went with OEM from Sunrise Ford. Swapped my factory one out with a 6* Delta when I replaced headgaskets and other goodies. New one sits a 0* with a low HP tune.
Don't skimp out on a cheaper one since if you're digging that far into it.
JMart
DFW
Yes, go with the OEM oil cooler. I bought one from Pacific Performance Engineering and it split a gasket and started leaking after 500 miles. Since I had to tear back into it I swapped it out for a OEM at that point. Delta's were around 10* with the PPE unit and dropped to 0-3* with the OEM. I am pretty sure the PPE was just a repackaged Dorman.
slc6oh
Utah
What about bullet proofs?
im sure its great. and to some its more feesible. but too spendy for my blood, specially when a properly maintained factory system works just fine for most all situations.
Bobbys6.0
felda Florida
We changed a few oil coolers in the passed 3 months witch the customers went with Dorman and haven't had any issues with them. I remember cause we all had bets on how long they would last... But as for me I would go with the oem..
slc6oh
Utah
yeah dorman made it a year in my friends case. then the mount o ring was leaking bad.
it got an oem one too.
