White smoke after fuel lab and regulated return.
Knoxville,tn
Got my fuel lab and driven diesel regulated return finished up this weekend and now on startup after sitting several hours she white smokes like it's 0 degrees outside. Temps are in the 50-60's so I don't see it as a cold problem. Is this a new characteristic of new fuel system or an underlying problem. My injectors have been having stiction problems lately and rev x is on the way. Any thoughts? Old fuel pump was full of **** from a bad transfer tank maybe that could be a problem. Not sure where to go from here
IIVonnyII
Langley, BC , Canada
I would imagine injector issue underlying as you had mentioned. try the rev x and see if it makes a difference. how is it running? is your EGR ******d?
