white smoke periodically
Nick284
Buffalo NY
hey guys, so trucks been running great. single s467. i blew the oil line a month ago routing to the charger, pulled over fixed the line and added oil. so since then ive also routed my ccv into the exhaust. i i get white smoke at random, after start up at first take off leaving the driveway. and if i drive for awhile then all of a sudden white smoke out of the exhaust. so im guessing its burning oil? coolants good, no leaks, etc... my question is, when i blew the line, did i blow a seal in the charger and now it leaks oil into the exhaust housing? or could it be a build up of oil residue my ccv is leaving in my exhaust? thanks, looking to fix it and its really annoying!
stroker221
indiana
I'd say its from the CCV to exhaust. If I were to route it to exhaust I would put a catch can in-between exhaust and oil canister to catch to oil before going into exhaust.. Moisture in boots could also cause white smoke. But I bet its from oil in exhaust and burning off.
78f100
Bonifay FL
I have had a bad turbo seal do the same, randomly came and went. Pull your down pipe and check for oil.
Nick284
Buffalo NY
I had that thought of putting a catch can in between. So i might do that. Yes good idea, obviously if i have oil in the DP i have a bad seal. Il have to check, i didnt think of that which is easy to find out ha. Thanks
B585Ford
WV
I lean toward turbo seal. Make sure it doesn't smell like fuel - unburnt diesel fuel will produce a white smoke. I doubt CCV
Nick284
Buffalo NY
its most likely that. ive seen a bad seal once. question is, can i fix this myself? only had a turbo apart once and didnt even notice any seals or O rings. but really i wasnt looking for that
