white swallow build
Super08Duty
College Station, TX
Super08Duty
College Station, TX
Wasnt sure how the pump would look in blue, but sense we were putting on the new IC pipe we decided to take the pump off and spray it for grins. Hopefully the paint doesnt start peeling off right away. Got Mikes new dual fueler CAC pipe and all i can say is WOW, I felt like i should be installing it with cloth gloves. Fit is perfect so far. Still have to modify the core support to fit the new pipe. Morgan took some pics of where i want the BOV flange. Mike, ill send those to you as soon as morgan texts them to me. Not sure how im going to fab an intake, I can buy some aluminized pipe and weld it with my flux core mig but it wont be a good lookin piece. Should be getting some small things tied up after work this week. Getting anxious to drive this thing and hear the turbo spool up. Probably gonna pull the driver side fender well tomorrow and see if i can tap the ghetto pyro bung.
Motostroker
FYI, while its easy to reach. Weld up the pulley bracket between the fueler and the alternator mount. Mine had maybe an inch worth of welds on the whole thing. go ahead finish her up. Mine broke! pulley bent down and belt slipped off, got caught in fan....... it wasnt fun.
Craig@MFI
batteries have to be in factory location unless you want to run pro-street
Jhaddox
Negley, OH
If im reading it right (im probably not) it doesnt have to be in factory location in SS anymore either...you race it I don't so im guessing you're right
or is that a new change
My bad on the Hijack
NHRDA Super-Street S/S
» Heads-Up class with a 4/10ths Pro Tree, Pro Ladder by ET, Auto Start on
» 2wd Minimum weight: 5000 lbs (w/ Driver) ±1%, slick tires permitted
» 4wd Minimum weight: 6000 lbs (w/ Driver) ±1%, DOT approved tires required
» Tube chassis, back halved, 4-link, 3-link style rear suspension prohibited
(Note: Traction/Ladder Bars allowed)
» Hood/Fender Stacks prohibited
» All Exhaust must exit up and away from vehicle
» Must have OEM Style transmission (Note: Lenco, Liberty, Bruno, Clutchflite, Danco,
or similar prohibited)
» Engine must be forward of OEM Firewall
» Must meet NHRA and/or IHRA tech and safety requirements for MPH and ET
» Must meet NHRA and/or IHRA licensing requirements for MPH and ET
--- Rule Revision Effective February 1st, 2012 ---
» Fuel cells are permitted and do not have to be mounted in stock location
(Fuel cells must be SFI approved)
» Battery(s) are no longer required to be forward of OEM Firewall
