Who does studs between sc and md
Southmike
Stepdad poped a hg, lost about 1 gal of coolant.
He has a bone stock o5.
the dealer want to do bolts.
Who can hook him up, and how much.
Pms fine.
Thanks
Craig@MFI
give us a call were in baltimore md and can schedule a pick up
443-867-9948
Southmike
He is nc and drives to md.
I was thinking rudy or mpd.....
But he took it to dealer anyway,
Excuse me while I go pound my head with a rock.
Dealer is supose to have started already :(
phale
He'd be pissed if he found out it was only an EGR cooler wouldn't he.
Southmike
should they be replaced as well...i know delete would be ideal. but.....
this is stock truck dealer is only my mechanic mentality. :axe:
Worstenemy453
Fredericksburg, Va
stock headbolts would work fine in a stock application if those heads werent warped from the factory. He will most likely blow them again if that is the issue, seeing as Ford doesnt mill the heads on those jobs last i checked.
chappy
Marshall Mi
Whats scary is fords specs on whats ok with the heads flatness. You have non perfectly flat ones or a block and they say its in spec and then they pop again.
