StockCar#10
Yeah I hear that.
ditch it and go with Morgans setup. :lookaround:
I don't really know. It never did it before the dual fuelers so.....
Unless someone has other suggestions on what I can throw money at with no results or improvement. :doh:
We are running the RCD dual fuelers on our 2.6 pulling truck. Eric's tunes but the one thing I can't compare to your setup is the fact that our truck is a ZF6 so we don't have to deal with converter lockup.
It only surges when Sport drives it on the street and crams on the brakes after a stop sign shows up on a WOT run...ullover:
Eric has been great to deal with throughout the build.
Maybe I can get Luke to chime in since he was more hands on with everything than me.
Have anything to data log with?
I'm open to anything at the moment. Not only is it surging badly but it doesn't maintain rail pressure either.
I have been setting fuel pressure by reading off the block the whole time. Checked fuel pressure at the pump as well to confirm. And I can get the surge to go away if I apply more throttle and constantly accelerate or decelerate. It just doesn't want to maintain a constant rail pressure while cruising. No fuel in the oil either.Can you check the distribution block or T into the line from the block to the CP3 to see what kind of pressure it is getting? Or at least check just after the LP pump to make sure it isn't running out out pressure/fuel when start opening it up? I am sure you have already checked, but there isn't any fuel in the oil is there?
Again, I ain't nearly as knowledgeable as most people on this forum, but this cant be the EGR harness being bad because if the CP3 wasn't getting any amps, it would be full fuel.
Like I said I'm open to anything so it don't bother me if you mention anything I've already done. Lol
I don't get it. We haven't had this issue with any other of the 30+ vehicles running this kit
