Why can't you just bypass the intake with the coolant hose?
TxFireman1972
Beaumont Tx
Once you delete the EGR cooler, why can't you just bypass the intake the intake with the coolant hose, instead of dealing with all the bends of the hose to connect the intake down to the fitting on the oil cooler.
The GoGo Diesel intakes use a new fitting in the oil cooler and then route the coolant line straiit back to the reservoir.
Here is the fitting:
And I assume this blue line is the line running from that fitting back to the reservoir:
Is there anything special you would have to do (other than blocking the intake off), to do this on any EGR delete? seems like a lot better than dealing with the 180 degree bend on the hose connecting the intake to the oil cooler. Just thinking out loud.
