why would you need one of these??
duddy
sloshkosh wi
Its just for emergency shutdown in case the engine starts to run away. Like the engine starts running off its own oil, or starts running WOT and wont shutoff with the key. More or less a piece off mind saftey item but mandated by some racing and sled groups.
PSD-BLACK-CLOUD
TX
If you hit a gas pocket in the oil field on location the truck will run off the gas going through the intake.
Worstenemy453
Fredericksburg, Va
Im actually surprised that anything newer would need to worry about it AS MUCH as something older.
I know i read on oilburners that an IDI turbo ran away and sucked a phonebook through the intake. I guess if its true then 21.5:1 compression does work.
Im surprised that Dodge stayed together that long, damn.
Jeff@Spartan
Georgia
12 valve bottom ends are tough. I would guess it was a 2.6 or 2.8 puller. Probably built to withstand some RPM.
Houston, TX
you would be suprised on how many 6.4s and 6.0s will run away, especially with a crankcase full of fuel. lol run out with the keys in your hand till it pops!
:jawdrop:
Worstenemy453
Fredericksburg, Va
I believe you could shut it down with water, but if you want any motor parts left i wouldnt.
I wonder if a fire extinguisher in the intake would kill it.
Fly By Night
Four Corners
If its a manual couldn't you just dump the clutch in a tall gear? That wouldn't work on any 6.7 but the older trucks it seems like it would.
moose99psd
sunny central oregon
when i worked for the ford dealer back when the 6.4s first hit the market we had 3 come in with run away conditions from cracked fuel lines filling the crankcase with fuel..
HaysKSFirefighter
Valley Center, KS
A CO2 extinguisher would be what I would use in a best case scenario...shoot it in the intake and it will displace the o2 long enough to kill the motor without causing damage, unlike a dry chem, or water extinguisher.
