Will 325 50 22s fit ?
PTSUPERD
On my truck...with 22 x 10.5s with the addition of just one more inch? I clear 35s on 9's with 2.5...but it's close...
Be ok with 3.5 inches? Not going up in tire size...just stretching the tire out a touch more...
PTSUPERD
^^ This is a 22x10.5 on a stock height truck with what I believe is 305 45s for reference
Matt
Minnesota
Mine are starting to pit a little as well, and I haven't ran them for more than 8 months. I do kind of want 22s as well. Haha.
6.0dirtworker
Cloud 9
I didn't know bmfs had a problem with pitting. Have a couple buddies with them for years now and still look perfect. Great to see your taken care of, and now your getting the 22s like what you wanted all along coincidentally. Thank god for pitting haha
Daryl@TDP
Chesapeake, VA
They worked with me on mine but it was after about 4 months. I think they should fit Gare your truck has good clearance now and the extra width should clear. I'd def try it before I went up any.
SAK
Victoria, Texas
They will clear Gare, you might have to pull the inner fender liner back a little. I was running a 20x10 with a 12.5 wide tire on a 2.5" and all I had to do was pull the liner back a little bit.
PTSUPERD
Thanks David. The driver side in a hard turn comes close to hitting the bottom of the fender opening. That's with the 20x9's (5" b.s) on 12.50s I have now (2.5" level kit). The 22x10.5's had a 4.7 b.s so I'm thinking it will push the tire out 1" overall right?
fender liners are already pulled back. nothing hits now except scrub on the arm at full lock.
SAK
Victoria, Texas
It's 1.75" offset more. So with 3.5" total lift you will be ok.
I don't remember what you are running for a lift right now, but you will need a Adjustable Track Bar and Alignment Cams, drop brackets or ALA's to keep the Caster right.
