Will it work?
UNBROKEN
33/12.5/22 on 22x10 on stock height 2015 F250?
What offset would be best for the wheels to stick out just a couple of inches?
ChattyCathy
I run 325/50/22 on my truck with AF 22x 10. Not sure on offset... Did have to cut a bracket off and trim. Stock 350...
Dzchey21
wyoming
offset would be about a -25 or so with that wide. Its going to be close tho, they really need a leveling kit but you can trim the fog brackets and pull back some innner fender ect and make them work but for the look you want -25 is about 2 inches out
ChattyCathy
I have a Icon .5 lift or maybe it is 1 inch you can have if you want....
ChattyCathy
Yep this is all exactly right.
UNBROKEN
I don't mind a little trimming...I just don't really wan to lift it any. Basically just want wider, nicer wheels than stock.
Dzchey21
wyoming
Then that's your ticket you could run a 305 45 22 but the load rating goes way down and tire tread options
yfz04drt
What bracket did you cut off and what did you trim? I'm rubbing the bracket holding the bumper and the back of the fender well. I've searched and could not find what everyone trims except the fender liner. Thanks
ChattyCathy
I removed that bracket thingy that is in the front of the front wheel well. It looks to support the valance I think etc... Didn't effect anything on my truck. I also trimmed a lot of the fender liner on the back side of the wheel well.
Athens, IL
Stock height 22x10 with 285/65/r22 terra grapplers. They work out to like a 35/11.50/22. No cutting or removing brackets. Just pull the inner fender back or trim it a little. I haven't and mine rubs the liner about 1/2" of it. I'm just too lazy to take a knife to it. Other than that it doesn't hit 90% of the time.
ChattyCathy
Do you have a straight on shot and a side profile shot? I could post mine like that so we can see the difference..
Love that truck also!
powerstrokin15
Charleston, WV
my dad has a 20x9 incubus -18mm i think,with 35/12.50s stock height.. i realize your offset isnt the same. but he has minor trimming to fit a larger tire than what youre asking
Athens, IL
Thanks, it's similar to yours. I would love black like yours. I know I won't keep it clean enough where I live.
It's raining today, didn't have any good true side and front shots in my phone.
UNBROKEN
Did both of you do some painting on the grille and bumpers?
I want a tri-coat white Lariat but can't figure out on the website how to order one without the chrome bumpers and grille surround.
ChattyCathy
My grill is painted but the bumpers are wrapped.
Hendrys2009
Baytown, Tx
I am running 22x12 with 33x12.50 toyo mts on stock height up front and block removed in rear. Had to trim a little on the bumper bracket and pull fender liner back a little.
UNBROKEN
I haven't built a 4wd....ever....but my gut says the 22x10.5 BMF wheel won't be too bad with a 33/12.5 ?
I know I'll put the 2wd front valence on....does that make any difference?
