will the egr and dpf from a 2015 swap onto a 2012?
jcain
The 2012 has a 2015 swap with factory piping not aftermarket. I recall the egr having an extra hose or something?
Just curious...
charles henson
My guess is yes but theres a bung that'll have to be plugged,maybe soneone else can validate this.
Fox
FL
the coolant routing had changed, earlier trucks had both cooling loops involved, 2015's have cut out the secondary system from the EGR cooler.
The coolant ports are the same, but there is a temp sensor that was removed. at first a brass plug was used to block the port, now it seems the hole has been eliminated from the casting.
That's what I've noticed eyeballing new trucks coming in at least.
Couldn't tell you on the DPF either though.
