Powersmoker
Anyone running more than 80 PSI with only fire ring grooves machined in the heads?
How much valve spring pressure are you running?
Hows it run Brian? I see you're taking it easy on it breaking it in, 80psi.
Lightning runs around 115-psi boost with only the heads cut, never had an issue. As long as the machining and hot retorque are done correctly you should be safe.
