WTB: Drver side tow mirror
dmd
Denton, TX
Driver side manual extendable tow mirror, power adjustable mirror. Would prefer
it has adjustable lower mirror (came on 2000.5 to 2003 (I think))
dmd
Denton, TX
One more try in case someone missed it...
If I can't get one, should I go with the same style with the running lights or with the
newer square style?
Probably have to be China knockoffs, OEM are pretty expensive.
newer square style?
power lower mirror?
dmd
Denton, TX
The original convex lower tow mirror before the late 2000 model would not adjust. After
that it was adjustable but was not power. Top large mirror is power adjustable.
I believe that the late 2000 had the lower mirrors adjustable, and had a trans
cooler in the lower part of the radiator. Also still had the lights that worked in the
doors inside panel next to the reflector for when the door was opened.
ok, i was confused when you said power mirror, lower adjustable.. lol
all auto trans have lines going to bottom of the radiator.
dmd
Denton, TX
Thx, I got a set of the newer style square mirrors from A1. They are nice, only problem
was that the paintable or chrome to cover would not click in snug. Had to use a dot
of glue on the tab to make sure I didn't loose them in a car wash or a branch.
