WTB: OBS stuff
Derek@Vision Diesel
Canby, OR
I need a front tank (metal tank) fuel pickup/return/sending unit assembly. Everything that screws into the top of the tank.
I also need the assembly in the dash with the orange pointer that shows what gear your in.
2 of the little black tabs that show if the doors are locked or unlocked, rear doors on a crew cab.
Need both pieces above and below the steering column, plastic pieces that are removed to insert a column pod.
Also need a very good shape drivers side seat in grey, mine is breaking down internally and the bracket it slides on is cracked. (local is probably a must though).
Countryboy07
N. Manchester, IN
I may be able to help you with the front tank... However, I'm not sure if it is metal or plastic... I am only going to run a bronco 33 gallon tank in the rear when the conversion is done.
Shipping may kill the deal though. PM me if your interested in working something out.
-French
Derek@Vision Diesel
Canby, OR
-French
I dont need the tank, i just need the sending unit that is screwed into the top of the tank....
Biggreen96
Visalia , CA
Ive got a full sending unit pickup assembly , 120 shipped if you want it. And I believe ive got both piecrs for the steering column that ill throw in for free.
Derek@Vision Diesel
Canby, OR
Biggreen i found a sending unit closer to home, thanks though!
I got the gear selector for the dash, the lock indicator for the door, and the sending unit...
Basically just need a good lead on a 100% complete and raelly good shape drivers seat. Mine is getting pretty bad internally
