WTT T4 68mm charger for GTP38R
Smokin 6.0
Indiana
I have a 68mm HX50, T4 mount kit complete from Irate, intake spyder is a custom one made from existing intake Y, uses factory intercooler tubing and comes with a custom fabricated downpipe will come with clamps and oil feed and drain lines. All i need is the GTP38RR, uppies, the intake hose on the turbo and your intake spyder for a super duty. Preferably bellowed uppies. Would trade straight up
Smokin 6.0
Indiana
Going back to alittle more reliability. This charger is capable of over 60psi I've had it to 40 with stock sticks and Tuning. Takes alittle while to spool do to the 1.15 exhaut housing but I have pulled 7500# with it. Keep in mind that was with stock injectors
CarportMechanic
WA
Im interested.
Is this a T4i mount?
Anyone know how well it would work with some 175/80's? Id also probably go to a smaller housing due to having a manual and towing a lot. Not sure how this compares to a 38R.
Powerstroker7.3
waxhaw NC
It would definitely flow more air then the 38r but with some 175/80s a smaller housing would probably work better but you never known
Smokin 6.0
Indiana
When it lights it goes even with stock injectors. It just takes alittle while to light with stock sticks. I was told it would be good with around 200/100's or 238/200's. Not much over that I'm sure 175/80's would do good with it.
CarportMechanic
WA
