X codes bought, but what about the rear?
little luke
Union County, Kentucky
Ok as the title says, I've bought a set of x code springs front the front of our x. I have a set of Firestone air bags in the rear already, is this going to be enough to keep the rear end level or higher then the front? If not could I just add a lead as opposed to buying a whole set of springs. I'm on a 600 dollar budget for this thing springs have burnt up 250 already and I still need shocks(any recOmendations?). And how big of a difference is there between using the stock sway bar vs an after market ones. ReasOn for all of this is the springs have gotten to the point where they tore off the bump stops and set roughly 3 inches from the frame. Borrowed the truck one day and pulled a load down a gravel rode and thought I was going to brake my back when the springs slapped the frame.
OBSWIZ
Wellington NV
Your going to need a adj track bar, correct bilsteins and B code SD rear springs..
We have helped thousands fix the Excursion suspension problems..PM me if I can help.
Cary
