ghohouston
Finally getting my truck going again. Put the slave cylinder in tonight, and when i pressed the rod in to get it past the fork, it forced fluid out of the slave cylinder itself (from the grommet). This definitely means it needs to be replaced right? I have no experience with hydraulic clutches, only big truck clutch systems. I made sure the master was full, and had someone pump the clutch pedal, hold it to the floor, and opened the bleeder on the slave MANY times, with no fluid ever coming out. I tried bleeding it the exact same way i have always bled brakes.
