6.4 2.5 pulling truck build
BTW the shock mounts are from leaf spring Superdutys. The passenger side was the easy side. I just drilled 3 holes and put 3 bolts in.
Now the driver side was a bit tricky because of the steering gear box plus the frame is angled right there. The top 2 holes I was able to use bolts and I just drilled and tapped the bottom hole. I also had to use washers to shim the shock mount so it would sit square with the frame.
coil spring front get hop that bad?
Rubenk
KCMO
Awesome build! I dig the shock setup too, clean and simple.
And yes they hop BAD stock, not to derail, but I havent seen any other videos so i'll share mine from last weekend. I put a 4-link on Friday and pulled again yesterday and wheel hop is entirely cured now. Look forward to seeing yours in action!
https://www.youtube.com/watch?v=-fsQXqB2go0
packin45
Rubenk how low does the 4link bracket sit on a stock height truck? I've been looking to upgrade my 2011 but the PMF website says it sits low on factory height.
Sent from my iPhone
Rubenk
KCMO
Mine is factory height F250, i'd say maybe a few inches lower than the factory radius arm sticks out?
packin45
Thanks for the picture. The lower link looks about level, so that's not bad.
Sent from my iPhone
TY'S08FX4
Ontario,Canada
Just read thru this hadn't noticed it till now, looks great! cant wait to see it run, im hoping to build a full time zf6 puller next winter with the parts from my current 6.4 pull truck. Good luck!
gman1
Michigan
Somehow I have missed this thread. Cool stuff man, you get it up and pulling soon.
Thanks buddy! Cant wait to see the silver bullet run.
Thanks. Ive been watching your threads on your puller. Lookin good!
jimdawg185
Whens the first pull? I want to hand deliver those decals!
gman1
Michigan
LOL Thanks! Test and tune is June 3rd in Peck. Not sure if Im gonna get the truck done in time. It will be close. If anything Ill be there spectating. Ill keep in touch with you as we get closer.
B585Ford
WV
I'm not sure how I missed this, but this is an awesome build so far Joel. What clutch are you going with?
