ncollins64
Good progress. Clean and simple
coil spring front get hop that bad?BTW the shock mounts are from leaf spring Superdutys. The passenger side was the easy side. I just drilled 3 holes and put 3 bolts in.
Now the driver side was a bit tricky because of the steering gear box plus the frame is angled right there. The top 2 holes I was able to use bolts and I just drilled and tapped the bottom hole. I also had to use washers to shim the shock mount so it would sit square with the frame.
10-4, fir some reason i was thinkin they didnt hop as bad..Yes they do. Doubling up the front shock cures the hop. ALA,s and 4 links also eliminate the hop.
Thanks buddy! Cant wait to see the silver bullet run.Somehow I have missed this thread. Cool stuff man, you get it up and pulling soon.
Thanks. Ive been watching your threads on your puller. Lookin good!Just read thru this hadn't noticed it till now, looks great! cant wait to see it run, im hoping to build a full time zf6 puller next winter with the parts from my current 6.4 pull truck. Good luck!
Whens the first pull? I want to hand deliver those decals!
Southbend 3850
