forcefed6.4ford
Ok then.
Ok then.
I have reasonably close to his build list in my truck, with a 71/59, i dont have a wastegate, and i need one.
its not from a bp point, its i'm borderline over speeding the turbo's. in a mild tune.
in my hot tune, i already know i can over speed them.
long conversation with my builder about it, and with bp's not exceeding low 70's, i'm over speeding them based on the abnormal sounds it makes. sounds associated with, in his experience, over speeding turbo's.
Which turbos and what are your mods?
It says 71/59
after the thread i had a while ago, i'd rather not go into it.
.......stock replacement 71/59
as for mods.
de-lipped and coated pistons, lowered compression 1 full point.
hardened seats with a valve job, new seals/guides etc etc
new lifters
stg 1 valve springs
stg 2 push rods
stg 1 cam spec'd for towing with some playing
rcd style intake. bought a new one and machined the plugs out.
no limit cold side and intake
arp head studs
ccv reroute
gearhead tunes on a livewire
stock trans
all on 100% stock fuel, 120k on all fuel system.
there is zero lag, lights literally instantly from a dead dig, and as i said, in anything more than a just over stock mild tune, i over speed the turbo's. i need both a wastgate, and larger turbos.
we knew when we did mine, that the 71/59 was going to be close to to small but we thought it would be ok. and it is ok.....in a mild tune.
which don't get me wrong. my current mild tune is more than anyone really needs on the street. it feels in comparison to my hot street/kinda race tune before the internal work.
when i put my race tune in, it will light up the tires in almost any gear but od effortlessly.
i'm very happy with the end result of where my truck is now.
i'm going to do exhaust manifolds/up pipes and a wastegate hopefully this spring, along with larger turbo's hopefully in the fall/winter of next year and call it a day.
Thanks. my reason for asking was that it made me wonder why you would have a problem with overspeeding the turob on stock fuel. I don't think I have that issue because after 26500 miles, if I was overspeeding the turbos, I am sure it would have showed up already. I won't make this a 1 turbo is better than the other, but it seems to me if you were having an overspeeding problem, there are 3 main possibilities:
1) Crappy turbo that can handle the RPMs of the compressor.
2) Super efficient turbo which speeds more than others under the same conditions.
3) The other upgrades which increased air flow also caused an increase in the RPM of the turbo.
...or a combo of all of the above.
we spec'd the cam to drive the turbo hard.
my comment to him was this.
i want it to light instantly. period. response, response, response. oh, did i forget response? and thats exactly what i got. peak rpm's do not matter me. i had it built around the premise of low end hooked to a trailer light that damn turbo and get rolling i got chit to do.
we went with the 71/59 thinking it might be to small, with the understanding that larger turbo's would likely be needed.
and at the time of the build, funds were rapidly disappearing the farther we got into it, so that was also my call to go with the smaller set. even if it meant i needed to drive in a mild tune.
Some valve train parts from Morgan
Also one of the heads has a crack from a seat to the glow plug hole. Does anybody have any good uncut cores they would sell?
Lookin good!
Finally getting this thing going.
