Any improvements in modded hpfps?
johnp115
Southern MD/Charlotte NC
Gotcha I understand it's not a "loss" of hp but there is a parasitic draw from it. Just interested to learn if a bigger pump would also in turn draw more like 2 do.
TXlineman83
Austin, TX
So here's an ignorant question. Does a dual fueler setup completely replace the factory HPFP. I'm not sure I understand the concept there.
In the KISS method or " Keep it simple stupid" a single is my best option in my eyes. A little insight perhaps from the more knowing please
Athens, IL
Dual fueler means adding a second pump. So you would have your factory pump plus another factory pump. Ergo twice the amount of fuel than a stock one. And still just as reliable as a a stock one. And most of the time they are only running at half capacity.
TXlineman83
Austin, TX
My truck is a Feb 2007 build
B585Ford
WV
With that being said I think a reliable single pump capable of 800+ hp is a great thing. I know I'll be buying them once they are ready.
As was brought up by stroker777, is anyone running your kit just off the pulley right now? I seriously considering this option...what does it take to make it work?
Athens, IL
You could it would just take a custom line to cross over to the passenger side rail and bypass where the pump used to be.
If someone really wanted one I would get a line made. But right now I'm not planning on it.
B585Ford
WV
Thanks. I need to discuss this a little more. If I knew it would fix the problem for sure, I would do it right now.
