No crank after new motor
Lmgrpowerstroke
Hagerstown MD
Just finished install of swap. Turn key to ignition and vac pump comes on. Gauges are good but when I go to turn it over there's nothing. I have checked all wiring and everything is connected. Reloaded the tune and I'm stumped now.
webb06
Seneca, MO
Use the starter relay wire located near the passenger side battery. Single wire round connector. Jump that to positive terminal and see if the engine cranks.
78f100
Bonifay FL
WHS.
There are three grounds also one by pcm plug, one on left firewall behind battery, and one under truck to frame on passenger side.
