Midnite Brawler Build
I can't believe you decided to stoop to that level but since you did, I don't mind bragging that last Fall I ran the 1/4 mile in 24 flat. According to my trap speeds, I was pushing 600 HP so it only took me 11.5 seconds to shift gears. I bet your auto can't compete with that.
Holy speed batman-better slow down those shifts...your truck is faster than mine LOL
PMF Stage Two Bolt-On Traction Bars
Big shout out to PMF. He makes quality pieces and everything is perfectly in order even down to the packaging. Here are some pics of the packaging, pieces and install...
just a tip for anyone installing this kit, on the drivers side, make sure you put the big bolt for the poly bushing thru BEFORE you mount the box up or you will will be taking it off again as the bolt won't clear the shock mount. LOL
this kit is silent and feels really stable. the other cool feature is one end is LH thread and the other is RH thread so you can adjust the preload by simply loosening the jam nuts and twisting the bar.
Very pleased-thanks Trevor.
Torque
GA
Wow I never thought about unbolting the up-pipes at the manifold. Glad I have 6.0 style manifolds now. :pimp:
