Street max on 11-14 fuel?
Athens, IL
Yes. It works. Just have to keep pw in check. A big 2300us tune will eat a 2015 turbo. Around 1600us is safe. More fuel can be ran but at that point you need to have gauges to monitor boost and ebp to make sure they don't get out of hand.
Powerstroked162
On Da Juice
Wa. State
Guys running heavy tunes and dual fuelers with the 64 are most definitely going to want a wastegate kit, which I have. Don't be skeered to let them eat :)
559 hp seems high given I thought our fuel is good for 500.
Think that was a generous dyno?
I dont think so but i dk, it was the first time on that dyno. Most guys were complaining that the dyno was reading low but hey who knows. I have seen that stock fuel is good for just about 500 hp so i dk.
11-14 or 15 pump?
12 pump low mile.
I have a stroker pump to test but the dyno that i normally use has been broke, it should be working next week so ill be sure to get accurate numbers before and after. Its on Hallers Dynojet that has been said to be stingy but i have always trapped what the numbers say.
1330us on a stock 12 pump at about 33 psi
I am also at 6000 feet elevation, as stated its laggier than a 11-14 turbo but once you get the tuning right it drives awesome. I am super super happy with the turbo, drives good and makes way more power up top. Runs super clean. I'll get more data next week hopefully weather should be good for some testing. Ill test at the track too in May to back up the numbers.
Cheap6.7
Rockisland County IL
12 pump low mile.
What tunning are you running?
Looking forward to what you come up with.
Codydiesel
West palm beach, florida
My track times that I ran with my non vgt match up with dustins dyno numbers pretty close. We both are on factory 12 pumps and 1331 pw, I doubt 600 could be hit on a 11-14 pump but you can get fairly close.
No 29K pressure at 1330 us, that the most i could go tho. I went 1350 and it started to drop to like 27.5k so i went back down to 1330.
Im hoping that with a stroker pump i can run 1600 and hit right at 600 hp
Buck1
Winchester, IN
Like what I am hearing. I am pleased with my Tow max and 15 pump. Lost rail pressure once and died going down the road, so keeping an eye on that and will be looking for a stroker pump in the future.
