PsRumors
My oil cooler needs to be resealed, when it turned off cool last fall it put some coolant on the ground and every once in a while I get a whiff of coolant. The truck is also due for an oil change and coolant change.
While I am doing the reseal, coolant flush and oil change I figure this would be the perfect time to do Evans IF I was going to use Evans.
I've read some thoughts here for the 6.0 and 6.4 but couldn't find info in regards to the 7.3s especially the eary 7.3s
One of the reasons I am thinking Evans is the good ole green coolant seems to be harder and harder to find. You can find the 50/50 mix but straight green coolant is tough to find around here.
Thoughts?
Thoughts?
