How many miles has it taken to clear up white smoke from injector install?
Carolina444
Dallas ga
I'm still getting the white/blue smoke from a injector install.. I've had injectors out several times and I'm sure I've got them seated. I'm at 72mi and smoke dosnt seem to clear up. I don't remember it taking this long the last times I've done injectors
Carolina444
Dallas ga
I know I'm going to get "did us use the search option" lol
Guess I should have asked if anyone had a truck take longer than the normal 30-60mi to clear up?
PSD POWER007
Columbus, GA
Usually about 50 miles for me. But I drive the piss out of it in those 50 miles. And it usually takes about 100 miles before the start times are consistent. For me anyway.
Carolina444
Dallas ga
I haven't driven it hard really.. Few 3/4 throttle hits to see what the new tunes are like.. Truck runs and starts good but still smoking a lot at idle
mandkole
Northwest
50 miles is not usually enough to clear up residual oil in the pipes. How much smoke? any miss? hot smoke too? I helped with an install that did not clear up after 100 miles but it had a miss also. One injector was unhappy.
Carolina444
Dallas ga
It's a good amount of white/blue smoke and it has that heavy exhaust smell. I don't notice it smoking while driving just at startups and idle. Truck idles smooth and no miss
DEEZUZ
NO PUKESTERS
NWI
30 minute drive cleans them up. That's with factory cat and muffler...
DEEZUZ
NO PUKESTERS
NWI
Hell, I've even high idled them for an hour or two when at op temp.
On days when I can't test drive
Powerstroke Man 6.4
My truck took about 30 WOT runs back and fourth down the road with 160/100s. popping/bogging/misfiring and making huge white smoke storms LOL. Thought something was wrong at first but got better better and better. Drove it from the shop it was at to my house (40-50 miles) by the time I got home it was all good.
Carolina444
Dallas ga
Guess I'm going to run the piss out of it today and see if it helps.. I drove it to work today and it didn't smoke when I got there but I turned truck off and restarted and it sat there and blew smoke while idling . So I don't know
cbf9703
150ish once.. but that is when i thought you had to be easy on it.. go hammer the dog chit outta it.
This. Not sure on an actual distance, depends on how we are driving the truck after the install. It always takes longer the easier you are on it, but a 30 minute drive usually does it for me to clear up smoke at idle and long cranking time.
Carolina444
Dallas ga
I'm right at a 100mi of normal driving.. Im going to run it hard today and see if that helps
let her get up to temp and go wot till 80mph.. slow down and repeat.
This will work the best...
also if it doesnt break the tires loose at some point doing this, you need a bigger set of injectors, lol.
