Radioflyer
Radioflyer
The fab guy's apparently gave me the "special" hot side pipe....LOL
**View discretion advised**
Radioflyer
Got the truck back last night, letting the turbo get a few heat cycles before I get on it. Just the little bit i've driven it, it spools pretty damn fast. And is LOUD. :evil
High idle comes on it sounds like a 7.3 LOL
I'll have vid's once I get a couple heat cycles through it. :thumbsup:
Radioflyer
Here's some pic's. yes the engine bay is filthy...I know it just came outta the shop last night. It's getting a good cleaning today. LOL
Radioflyer
This thing drives hard, moves some air and spools crazy fast. I for sure need more fuel on top. In the 'Street' setting of my xrt, it's around 1300-1400us for tune, 45psi of boost and won't go past 1150 for egt's und a wot run. Doesn't bark what so ever in between shifts and sounds like a freakin Dyson when above 20psi. Hopefully i'll get it on the dyno just for hp comparison on the same H&S boxed tune that I did the 584 with the 66. That tune runs around 1700-1800us. From there, start tweaking the tune and seeing what I can push it to on stock fuel. :biggun:
Radioflyer
Update, tap shifter is going in tonight after the phones turn off. I'll post pic's of the install tomorrow. :thumbsup:
Radioflyer
Here's a pic of the lever installed and of the the gear indicator. I thought the indicator would be bigger bit it's pretty compact and out of the way. The lever I will say is a little bit getting used to. Oh, and these things do not agree with CTS's at all. LOL
Radioflyer
I have mine set in the full manual race mode and It is a blast!! I really like the converter lock out or lock up option in tow haul with 4th and 5th. It's smooth going into the manual control too. When driving, just hold down the "-" button down for a couple seconds and the gear indicator will light up indicating your current gear, then you just click "+" or "-" to select what gear you want. To lock up the converter, just click the tow haul button and it'll show on your dash tow haul is on and you'll feel the converter lock. If you want to go back to normal tcm tuning, just select the "+" button until the shift indicator goes back to dark.
does it only mess with the CTS when the shifter is activated? or all the time.
Radioflyer
Yes, only when I went to activate the tap shifter is when I saw issues.
What does it do to the Edge? I have a CS purely for monitoring, would this have any effect?
My CTS is an insight as well. One or two things would happen, either the gears wouldn't change and the function of the tap shifter was irratic, or the cts would shut off or blink.
