levelling kit questions
mattl140
canada
getting a levelling kit for my 99 f 250 and it come with the track bar drop bracket do i still need a adjustable track bar? or will it be fine thanks.
mattl140
canada
do you have a levelling kit? did you use just the drop bracket and stock track bar or adjustable? thanks
ghostriderblk
I run rough country 2.5 level kit it comes with new and longer bar and springs. not a fan of the stock spring bushings rough country's come with poly bushings. Anyways sense your dropping the the bar with a bracket instead of lowering the bar it compinsates the angle difference and no new bar needed. I'm guessing your doing a shackle lift of course..
mattl140
canada
I'm doing a spring lift this is the kit http://www.superlift.com/lift-kits/2-inch-1999-2000-ford-f250-f350-suspension-lift-kit.asp
hunter scar
I have a Zone 2.5 leveling kit, which is a mini spring pack It come with an adjustable track bar and new u bolts. I ordered zone shocks with it. It all seems to be good quality stuff. It rides good and I believe everything I ordered was cheaper then the super lift you posted
mattl140
canada
only problem is my springs are shot from plowing so i need new springs
mattl140
canada
my production date is 1999 feb 20 I'm having a hard time finding 2inch leafs to level out my truck does anyone know where i can get some thanks
ja_cain
X-codes should get you close. That's what I'm going with one of these days. Lol! Just google oem x-codes or something like that as I don't think the place I have in mind is a site sponsor.
mattl140
canada
do you think they will level the truck out i have 305/55r20 and 20x12 rims with -44 offset
dadada
Indiana
I have Pro comp 2" leveling springs in the front of my truck w/ a drop bracket for track bar. 20x12, -44 offset w/ 33x12.50's. Mine sits level but that is my truck. I don't have any blocks in the back either, my springs sit right on my axle.
mattl140
canada
they don't make a levelling kit with springs for my production date do you think i will be good with the x code springs, and i was also thinking of putting a smaller block or no block in the rear thanks.
dadada
Indiana
Here you go.
