do you have a levelling kit? did you use just the drop bracket and stock track bar or adjustable? thanks
I run rough country 2.5 level kit it comes with new and longer bar and springs. not a fan of the stock spring bushings rough country's come with poly bushings. Anyways sense your dropping the the bar with a bracket instead of lowering the bar it compinsates the angle difference and no new bar needed. I'm guessing your doing a shackle lift of course..
I have a Zone 2.5 leveling kit, which is a mini spring pack It come with an adjustable track bar and new u bolts. I ordered zone shocks with it. It all seems to be good quality stuff. It rides good and I believe everything I ordered was cheaper then the super lift you posted
I have Pro comp 2" leveling springs in the front of my truck w/ a drop bracket for track bar. 20x12, -44 offset w/ 33x12.50's. Mine sits level but that is my truck. I don't have any blocks in the back either, my springs sit right on my axle.
I think X codes would probably work.
X codes and stock 250 block out back
Tires are 305/55/20
Thankswhat offset are on those rims and nice truck man
