PSD POWER007
Who sells the BASB?
Irate Diesel.
Who sells the BASB?
Who sells the BASB?
Told ya......you'll love the BASB. Did you get the BASB with the billet wheel?I'd expect egts to climb towing over 10k lbs up a 6% grade for over 8 miles. It would normally climb 1300 while I was rolling but if slower drivers were hanging in the left lane (which they always do) and I really had to lug her, they would climb even more and I wouldn't let her get over 1400. This auto, with 34.5's, and 3.73's. So I end up shifting to third to make everything happy. Same climb same load with the BASB and I never topped 1050 on overdrive. I log tons and tons of miles each week and stay in my gauges. The BASB runs cooler, spools slightly lower, and makes more boost across the board.
My numbers based on the dieselsite d66 ww2.
Running empty at interstate speeds 38r would run about 3-5 psi and 600-650 get on flat ground. BASB will run 5-7 psi stay between 550-600 egt. Empty up standard type hills on the interstate, the 38r would run 7-10 psi and run 750-950 egt. BASB runs 8-12 psi and temps stay between 650-800 egt. Towing my same trailer mentioned above on the interstate on flat ground, 38r runs 7-10psi and 750-1000 egts. BASB runs 8-12 psi and 700-800 egts. Running up standard hills the 38r runs 10-15 psi and 1000-1200 egts. BASB runs 12-17 psi and runs 800-1000 egts.
I run the 38r with the stock wheel, regular ww2 and the d66 ww2. The d66 ww2 was the best performer on my truck which is strictly a daily driver/tow rig. The BASB I have only run with the billet wheel installed by Bell.
My truck is stronger tip to bottom running the BASB and it seems much happier in the 1500-1800 rpm range than the 38r on MY truck.
And FWIW my WG rod was completely tightened down on the 38r.
Here's something else for you. Towing mileage numbers all hand calculated. 38r stock wheel 8.5 mpg, ww2 8.8 mpg, and d66 ww2 9.2 mpg. BASB 10.5 mpg.
Empty, I was about 15 mpg with all 3 wheels on the 38r. BASB I'm just over 16 so far. I use my higher HP tow tune to tow, and my street tune running empty.
Who's tunes are you running?
Billy T.
[email protected]
I have a BASB and tow 21k in the East (PA, WV). I have 3.55s with 275s. I don't know the grade percentage but have pulled 5-7 mile grades. I could pulled them OD at 70 (1850 rpm). I'm passing cars and Got caught up in slower moving traffic which made me downshift into 3rd.
Billy T.
[email protected]
^^^^^^The common denominator = tuning.Twisted diesel automatic if you upgrade the injectors at all. If you run a stock injector and tuning or an ac/stock a torque converter and vb would be sufficent if you keep it cool.
Im done with the turbo.
Ive towed tons of **** with 35's and 37s around here with less power.
CurtisF did the same thing with 38r, 250/200, and 35s with COOLER egts so a 38r is capable even with larger amounts of fuel. Jus sayin...lots of no's but lots sayin yes too..
Iincolnlocker runs a 38r and he drives like a banshee in a 470 hp truck and his egts were enviably cool..
How does the basb like higher rpms? I am at 2350-2400 at 70 mph in fifth gear. At those rpms egt has obviously not been a problem while towing, around 900 to 950 or so. This is with a brute66. Much better than my stock turbo. One thing im curious about. When you install a turbo that moves more air than stock, like a 38r/basb/66, will your boost stay the same at a given throttle position? Or does the engine get the volume of air it needs at a lower boost since so much more air is being moved? Does the addition of an intercooler affect any of that?
Asking because my truck is pulling harder than ever but i believe the boost is down a couple psi from what i can remember from before. Its hard to be sure since i didnt have the stock turbo numbers written down. The truck just seems to work less than before on the same hills. Maybe its because i need less throttle to tackle the same hill as before, therefore im not asking the turbo to spin as much?
