BilletGarage
Hahaha that's good stuff, I love seeing the look on their face when they get spanked by a truck.
LOL His windows were pretty dark but I would imagine he was surprised.
no need for the ported fuel rails. and no, even a healthy k16 will only keep up with 15s for a short time. midwest's duel fueler kit is affordable. that and some 60s will maximize the 75/59 combo-should be 800+
I was going to do the tails this weekend and found I need to change the reverse light sockets.
Heads up. The 08+ tailgates stick out a hair, so if you go back to the 99-07 tail lights, you may need shim them a little to make it look right. I ran across this issue when i put an 08 tailgate on my 02 truck.
You can run a super strong setup by just doing larger turbos. It's pretty much a waste of money for 99% of people doing larger injectors with a stock single injection pump as it really can't keep up with anything but stock on a really aggressive tune. That thing will run awesome with just larger turbos anyway. Ported intake manifold is money much more wisely spent. You can do your own ported rails if you want. Done properly, there are no negative side affects. All you do is drill out the inlet to match the size of the outlets. It's 1/8" I believe. Just don't break off the drill bit as it's pretty hard metal. Some guys have had surging issues when doing ported rails, but good tuning completely fixes that. Also, if you go to a bigger, or dual injection pumps, the extra pump does rob power, so you'll want to at least do 30% over nozzles to gain any noticeable power. Even if you don't though, just adding the extra pump will make your off idle power a lot more snappy having exactly the pressure it wants exactly when it wants it.
i personally wouldn't port the fuel rails. smoke is all in the tuning-not necessarily injector size.No need for ported rails with stock HPFP or no need for ported rails ever? I want to keep things relatively smoke free so I'm not sure about dual fuelers and 60's. Not ruling them out, but not sure it wouldn't be smokey with a 75/59 combo even with PW dialed back. I figured a little more air and a little less fuel than a typical build might keep me clean? Not looking to chase HP numbers. I just want a very clean burning truck that spools quick and rips.Thanks for the input!
Thanks for all the info guys! I have contemplated a single charger setup. My only concern is smoke down low and lag. I like the quick throttle response I have now. How would a single 64 do with a small shot of spray? I have heard the stock HPFP is capable of about 700hp on a good day. Is that about right? Also, when is a wastegate "needed"?
Sent from my Note 4 using Tapatalk
Thanks guys! Letting all of this soak in. Would there be a significant difference between a 75/59 combo and a 72/59 combo?
And yes, keep me posted on your results with the HP turbo upgrade and 15's B585Ford. Thanks.
I know the Dragonfire Pumps have been unreliable but I wish someone made a 30-50% over modded pump for us guys who just want to run 15-30 over injectors and maintain rail pressure. Maybe modding the pump to flow 85% over stock is too aggressive and that's why they are failing?
I'm running a somewhat similar setup to yours just more race oriented (rcsb 2wd) and I'll say smoke control is all in the tuning. Duel fuelers, 60%'s and a 59/72 is almost smoke free on my street tune (1.8 pulse width) from gearhead. Fuel is pulled way back at this point but it's very responsive, clean and cool... And pulls very strong up top, defiantly need a gate though. Gets up to the 47-50 psi range quick
