school me on block fill and fire rings!
Magnum PD
VA
I took them my bare block, heads, and pisons. Block fill, new cam bearings, decked head mating surfaces on both. New inj cups and bored out the block for .020 over Pistons, radius cut the blows. I'll pm you the price.
hunterER7
How much that run if you don't mind me asking
was thinking the same thing. if you dont mind id like to hear what that ran you as well.
m j
BC Canada Eh!
fill pics - after the grout cured I used a carbide bit in my die grinder to open the water passages further
fire rings in block - done on a Rottler boring machine
m j
BC Canada Eh!
it was easy.
the grout kicked very fast.
it goes from 'this is way too liquid" to "start pouring fast!"
I think I went too tall with the fill, we shall see
the machinist had to order a custom cutter from rottler and he called Swamps for a conversation on the procedure
97stoker350
south central pa
Swamps will tell you just about anything you wanna know. I called the engine dept. Whenputting my motor together and they walked me right thru a couple steps right over the phone. They will always have my biz
Waxhaw, NC
The process is very easy just takes attention to detail.
1. With a bare block on a engine stand tape off the deck surface, front and at the oil cooler completely. Then cut out for the water passages.
2. I use 3/4 in poly hose and route water passages to the water pump holes on the front and the oil cooler ports.
3. Install your main caps and girdle.
4. Mix your filler till it will flow easily. It's easier to mix it in small batches. The consistency of the filler works best when it is about the same viscosity as cold oil or slightly thicker.
5. Begin pouring filler in the water jacket holes from the deck surface
6. Pay close attention to the level of the filler and that it even through out the block.
7. Once to desired fill, tap the block with a rubber mallet to get as many air bubbles out as possible.
8. Install deck plate and torque to spec.
9. Let this side sit for 24 hours. Then repeat for the other side of the block.
10. After about a day you should be able to remove the poly hose while the filler is still "soft" but will not run. Use a screw driver to shape up your ports
11. Alow about 10 days to fully cure with the deckplates and girdle installed before any machine work.
12. Use a carbide bit to further shape up the ports
That's it's very simple process
Sent from my SM-G920V using Tapatalk
hunterER7
Thanks for the run down guys. Any and all info helps. Seems straight forward for the most part. Now I'm just trying to figure out if I'm staying with the good ole 7.3 or not.
