6.4 Head gasket kit?
Craig@MFI
you will need headgaskets, intake manifold gaskets, 8 injector oring kits, the two new hp fuel lines going to each head, about 18 teflon banjo washers, rocker box orings, exhaust manifold gaskets, 4 up-pipe gaskets... that should be about it
superdutyfarmer
Tamaqua, PA
Okie doke, I just want to make sure that when i put it down for a week or so till i get everything fabbed up that I don't have to order parts after teardown and have to wait. I figure you have done enough of them. :ford:
superdutyfarmer
Tamaqua, PA
I agree, I'm probably gonna hit up sunrise ford for the small stuff. I got some more questions while i have your attention, I am doing head gaskets, sending the heads down the the machine shop to be checked and decked. I have a wastegate kit here and also the studs to clamp them down. I talked with Dave from swamps and he highly recommends to upgrade the spings. I was wondering as I have heard different people say that it is a good idea to put pushrods in as well. Lastly for now, do i have to worry about o-ringing the heads like the 6.0s, or is it not needed. Thanks for the help
White_monster
The great white north
Upgraded valvetrain is a smart choice. Upgraded pushrods go along with the valve springs. I'd also do hardened valve seats while the heads are at the machine shop.
BFT
southern cali
:whs:
you dont need to fire ring the heads.
it might be over the top but i sleep easier at night knowing its all done. you doing head studs too?
Craig@MFI
You don't need springs or pushrods if you set the truck up right but valve seats are a good idea
superdutyfarmer
Tamaqua, PA
What kind of proper set up do you recommend, I still have to talk to the machine shop about hardened seats, but I am open to suggestions on saving like 1100-1300 bucks on the valve train. that could be nozzles and a hpfp upgrade. I am not trying to make a million horsepower, all I want is a good solid daily driver that i can run my 345 tune every day and not have to worry about any issues with the motor. I do have ARP studs sitting here in the box, so that shouldn't be an issue.
Craig@MFI
Just dial the wastegate in good and torque those arps down good and call it good
superdutyfarmer
Tamaqua, PA
Sounds good to me, I appreciate all the help, I'm not trying to cut corners by any means, I just don't know everything and am not afraid to ask questions.
