dieseltron
Said goodbye to my obs
KBMKVIII
Finished wiring my quad e-fans rated at 7000 cfm. And got my new muffler in, waiting on the rest of it.
Tapatalking from a wind turbine
6fourstroker
Well, attempted to install my mini maxx, NoLim intake/egr dlt on my 2011 6.7.. Wired the mini to keyed ignition source, does the normal start up stuff then stays on "initializing communication" no matter if the truck is running or not. Won't do anything else. It's an original tuner, 1.02.3 .. I even tried a different HDMI cable and still same result
6fourstroker
Beautiful! I wanna hear this bad boy running! Sucker is clean as it was from the factory!
Will@Rudy'sDiesel
Burlington, NC
Try this and let me know what happens.
MAKE SURE THE KEY IS OFF
1) Unplug the ODB2 block from the ODB2 Connector.
2) Power the Unit up through the micro USB cord into the side of the Mini Maxx.
3) Once the Unit is powered up through the micro USB cord hit the top left hand button and it will take to the main screen.
4) Go to the Menu (Top left hand button)
5) Click select Vehicle, and turn the key to the run position.
6) Plug up the ODB2 cord to the ODB2 port located underneath the dash. Make sure that you do not unplug the Micro USB cord from the side of the mini maxx.
7) Now that you have the mini maxx hooked up with the Micro USB port and the ODB2 port, you may now select your vehicle.
8) Once you have selected your vehicle, the unit will restart. Once that has happen you may now begin to install the mini maxx to you vehicle.
6fourstroker
Ok I'll try that when I get home today! Thanks Will
6fourstroker
