6.4L complete motor build
StrokiNDieseL
Geneva, Fl.
After a long 11mos (don't ask!) of truck being down she's back up & produced 650rwhp on H&s mild tune. I'm happy for now until a duel fueler/Lp system is added b/c rail pressure isn't holding. Truck runs great & spool up is instant but smokey so I just did a revise from GH & everything cleaned up well. Now I just need a run w/these files loaded & see my real potential. Lol
- "new used" block machined/balenced w/standard coated/delipped Pistons on stock rods.
-cometic gasket kit
-stage1 cam
-side action lifters
-heads treated/flatted (no porting)
-springs/retainers,pushrods
-6.0 mani's- Hd uppipes w/provision
-WG dump to atmo
-bullseye Hp/Lp balanced wheel replacement
-newer HPFP w/30% 8-hole nozzles
-injectors flowed by Mpd
-Rcd ported intake
-No Limit Cai
-Alradco IC
-FTI TC, PTP shift sol in stock trans
-Arp's inside/out.
Funds ran out so that's why the fuel system was left alone but will be addressed asap. It's nice to search then endless threads from you educated ones around here & put it to use b/c this trucks an ANIMAL now! Thanks PSA
StrokiNDieseL
Geneva, Fl.
not many pics but here are a few shots
StrokiNDieseL
Geneva, Fl.
reason for motor build, thumping sound that lead to a broken push rod after tuned for 15mos @ 61K miles.
6.4f350
Nice. Just did a very similar build on mine due to a bent rod. Great power numbers, mine definitely feels strong as well.
Administrator
-cometic gasket kit
-stage1 cam
-WG dump to atmo
-Rcd ported intake
-No Limit Cai
-Alradco IC
-Arp's inside/out.
sweet ! email me an engine shot ! sales@nolimitfabrication.com !
StrokiNDieseL
Geneva, Fl.
I lost my cruise control, it's a speed saver (truck moves to good what can I say) for me durning my travels!!! who do I contact GH due to customer tunes or just try a reload?
Chit I ran my GH revised tunes (closed course) on a few WOT pulls & was showing 27Kpsi rail when before in was hitting 23-24 & dropping. I wanna put a go pro on & It to see if it's holding now. but nice job G3ARHEAD thus far & cleaning the smoke. It had hase at ideal to Ccv routed in exhaust but very happy! :ford:
Question Guru's running coated piston temps, recommend ranges? Thanks
Richmond IL
Thanks, I Pm'd on your fuel system but I believe I wanna run a sump also so lmk or I can call shop if that's better. Jayson
OK not problem man just had enough time to pop on here during lunch to check ill get back with ya quick as I can a lot going on around here :)
StrokiNDieseL
Geneva, Fl.
Truck runs like an APE, slight hase (I'm thinking ccv routed into exh). :pullover:
BUCKS on some excelerations. So I know I have to convince wife that these T-bars are needed too.. Another Dyno event on 10/3 I'd like to get on but working so maybe I can make something happen & run these GH tunes.
StrokiNDieseL
Geneva, Fl.
Just an update, added a Ad200/sump & holding rail much better. I know dual's are a must & that will happen at some point (bigger things in the works now) but she's an animal for sure. I'm dealing w/a one wheel peel & truck wants to go everywhere but other than that, love her! I ***'d :doh: up 2nd week & punched her on a dewy morning getting on interstate & lost her (that's what I get thinking I can control her after 9mos of not) but fortunately just bumper, fuel cooler, rear side gaurdrail damage that's been taken care of. Stupidity got the best of me & gave me instant karma.. Hopefully a new dyno run soon but more fuel may just have to wait on the drag truck, 2nd child, new house to satisfy wifey.
These 6.4's are looking like a thing of the past as the 6.7's are NUTZ around here & love the power #'s everyone putting down!
