97 7.3 engine swap or not...
RR570
So my question here is, should I swap the motor and all associated parts in engine bay plus(fuel tanks,lines and dash/harness)from my 96 7.3 2wd into my 97 460 4door 4x4 or should I put basically all my 97 460 interior,front doors, bed and back window in the 7.3. I was thinking that swapping the stuff from the gasser might be faster for the time being and that I would just run the truck 2wd until I had time to swap all the lift and 4wd components. Opinions please, I think that would help make my decision easier. Thanks in advance dave
SmokeyFreedom
Brookings SD
Cab swap basically. Move the 7.3/shenanigans over with cab off. Done a elect swap from 1/2 ton gasser to 7.3... id burn it to the ground and collect the insurance check before doing half that **** again. Keep cab together. Moving motor/tanks/ wiring on same basic years wouldnt be that hard but needs a 2 post hoist to go airborne twice.
Option 2: 4 wheel conversion. It sucks. Could do the Sky Manufacturing kit and use a super duty axle on a reversed shackle. gives a 4" lift and rides like a Cadillac
http://www.sky-manufacturing.com/cgi-bin/commerce.cgi?preadd=action&key=FORD-FSRSDAL-004
wadeclinton
This. My brother and I did a 4x4 conversion to a clean ex-cab 2wd we got a deal on. We used a PMF RSK and not a sky. With both trucks side by side and tools(torch,grinder,welder) it's not that bad of a project. You can find the thread over on PSN.
Rico
San Diego
My 97 460 was more reliable but driving a diesel is so much more entertaining. Four doors are dope!
RR570
Sorry so long to get back on here. Working like he'll. Just started the swap last week. I have about 30hrs in I have both motors out and the diesel inside harness out. Gonna pull the gasser interior Tom and put the harness and dash back together. Hopefully have it cranking on Saturday.
