need some input from 2011+ owners with 20x10's
1stock13
I have 35X12.50 at's on stock platinum wheels at the moment, I'm installing a 1.5 in spacer lift this weekend, my f350 rides high stock, but I want to make sure I can get a 20x10 -19 wheel under it with minimal rubbing. I want to know if anyone has done this, I'm guessing with the spacer I'll be around the same height as a 250 with a 2 -2.5 in kit. Any pics and input would be appreciated. Also, I would like to know the weight and offset of the stock platinum wheel. I'm pretty sure it's a 20x8.5 but I could be wrong.
250 or 350 has nothing to do with the front spring height. it matters what the truck was optioned with. check your door sticker front axle ratings. if it is 6000, they are the tallest springs avail from ford.
1stock13
I was wondering what that meant, yes that's what I have. It rides stiff at all get out. I bought my truck used and I find out new things everyday about it.
OuchThatHurt
Neah Bay Wa
3" rough country lift. 0 rub.
20 x10 XD hoss
35x12.50
yep you will just barely need to trim the bumper bracket and the inner fender should be solid.
I'm not sure. I am pretty sure the back space is 4.75. I think that's near -24 ish
Central Illinois
20x10 fuel w/ -24 offset w/ 35/12.50 Toyo mt
1.5" leveling kit...new springs not spacer
Kept the stock blocks in the rear.
Had to trim the inner fender out a little bit. Nothing major and nothing metal just the black inner liner.
Southern Illinois
I have 20x10 with -24 offset with 3 1/2 leveling kit/lift. I had to trim inner fender quite a bit and will most likely trim bumper support. Rubs occasionally when turning and I hit a bump just right.
1stock13
just installed the exact same setup, just trying to scrape up the money for the wheels now.
