someone should try it
SEABEE08FX4
Montgomery TX
Gotcha, are there any guesses on the numbers he's gonna put down? Will this compare to high powers?
If I had to guess I would say 750ish, back pressure is still going to be an issue with the modded stockers as the exhaust housings don't flow enough as is.
How ever I would think this set up would boost much sooner and pull much harder than anything else out there due to the nature of the setup.
CamTom12
Huntsville, AL
I think that back-pressure will be less of an issue than stock.
If he's gating around the "stockers" in order to keep combined boost under control, then there's less exhaust to get piled up in that madness. Some of the exhaust pressure will go straight to the big turbine and bypass the stockers totally.
SEABEE08FX4
Montgomery TX
It's possible I guess, just all depends on how it's routed. It was sort of hard to tell from the pictures.
This is my latest creation for the air filter... ugly but it works
Sent from my DROIDX
Nos_GTSR
Rexburg, ID
Its a 50mm turbonetics newgen HP. I guess were dynoing tomorrow, we spent all day working on Dmitri's new daily driver.
