6.0 low base oil pressure concern
webb06
Seneca, MO
Truck came in with low base oil pressure. Gauge would sometimes show oil pressure and randomly it wouldn't. Truck would still run and drive customer complained of low power though.
Hooked up a manual gauge and it shows less than 5-10 psi at idle. Cold is obviously a bit higher but not much. Popped out the oil filter and held down the drain back valve. Canister fills up like normal and holds the oil. At that point we knew the leak or loss of pressure was somewhere internally and after the lpop.
Dropped the oil pan and found this
Spun a cam bearing out of place. Unfortunately we didn't get to dig any deeper as the customer doesn't have the cash to fix it. Thought this might be a possible cause for anyone searching for this problem.
Atsah
Maine
Interesting.. A buddy of mine a few years back had this same issue, he was fed up with it at that point so he lit it on fire and bought a newer truck..
webb06
Seneca, MO
Like literally on fire?
Cutting-Edge Diesel
Newkirk, OK
I have a 550 XL that came in with no start hot. Checked the system for leaks and all was well then I noticed it's not filling the oil filter housings very fast and no low pressure oil when hot. But pretty sure it's a lpop issue. The cam bearings are odd normaly they are in very good shape unless the motor had metal go threw it.
webb06
Seneca, MO
We used to see a few lpop problems but here recently haven't had one. People always say it's from lifters coming apart but I've only seen one truck at our shop that way. Any foreign object can cause the scoring.
No clue what caused this cam bearing to come out. I wouldn't mind digging into the engine to find out for certain though.
Zmann
i hope he didn't claim that fire
or we all helped pay for his new truck
Nice find Webb
DEEZUZ
NO PUKESTERS
NWI
Only 2 things I've ever seen tear up an LPOP and that is lifters, which is about 99% of failures, and when we got that bad batch of circlips for injector seals and the collars were grenading and tearing up LPOP.
No other metal debris in this motor?
webb06
Seneca, MO
Not much else. Pulled the pan off and all that was in it was the cam bearing.
