bpan
- Joined
- Oct 11, 2014
- Messages
- 243
- Reaction score
- 0
Its always weird to me how you can get 2 totally different opinions on the same thing...
Anyone else notice that they changed the cold side intercooler pipe to a completely different design? Almost looks like a rigid radiator hose. Ford even references it as a Engine Coolant Outlet Tube on their site. I havent actually been able to grab ahold of one in person, but looks like the new design should help out a lot with failures of that plastic pipe cracking and blowing up being that theres barely any plastic anymore. Wonder if someone with an earlier generation 6.7 can use that new cold side intercooler pipe as a better option to the one they have to reduce failures. If it is more durable, which it should be, this would definitely be a great, cheaper option than buying the aftermarket intercooler pipe upgrades. Looks like list price through Ford is only $78.88. You could probably could get it cheaper. Anyone tried to fit one of these up on the 2011-2016s? I am trying to upload pictures, but for some reason, it keeps giving me upload error messages, so I guess you can google it to see what it looks like.
Pump shows same crossover.
Turbocharger is designed different, doesn't seem to really be much different in performance
I seen on FB with pictures, it's a rubber hose with the plastic quick connects still.
Has anybody found the specs on the turbo yet?
On powerstokehub it says it's an SST like the 11-14 but no specs. I am asking because I don't know anything about turbos and I hope it's not like my 2013
From FTE the new lower water separator filter.
because the pump is in the tank .
Is that square filter in the tank?
