Black Magnum 2.0 assembly
Magnum PD
VA
Thinking of powered coating my valve covers, fuel regulator mount, and maybe my Gen 3 Rez housing.
Magnum PD
VA
There is one that needs new bearings, turbine housing and shaft. I could get.
Magnum PD
VA
do it!
I painted the valve covers but, didn't last, they are bare medal now. Still fabbing up the regulator mount. Lot of wholes to cover up on Rez.
Powerstroker7.3
waxhaw NC
They are more expensive but I think worth it for a daily driver truck cause ball bearing spools faster than journal bearing
Magnum PD
VA
Somewhat dry pavement, yes dropping the clutch and holding the brake some.
It sounded ok in the spoolup video...the other one it sounded like it was missing pretty bad
Magnum PD
VA
One the stand? Yeah. One injector (or more),didn't have oil coming out of it.
Magnum PD
VA
Went ahead and did a hot retorque of the head studs. About a full turn to get them back to 125 ft lbs. Worth doing. Still have one injector not spitting oil out. May have to send to Tim.
Now gonna put engine back on stand, flip it over and inspect bottom end.
