Pro Stock Powerstroke Mustang
pardon my ignorance but how come all the issues with trans parts? Is the lenco up to the task?
Cutting-Edge Diesel
Newkirk, OK
Torque/an unknown problem we havnt found yet etc. Lenco will hold but it's going to be a fine line for sure. We may have to rev it out more to keep it from falling into the torque. Could also be a pod pressure issues down track and allowing it to slip.
Cutting-Edge Diesel
Newkirk, OK
Got the Lenco rebuilt again yesterday. Was going to throw it in and try and make testing tomorrow but we are changing our shift solinoid set up and won't have it till next week and decided not to risk hurting it again with our current solenoids. Plus we need to do some mainence on the motor that will take some time.
Might try and enter a race with it on Thursday and do some testing with it.
powerstroked08
Pennsylvania
Well that's good news! Hopefully you have the Lenco sorted out. What are you doing on the engine? The usual fluid changes? Or are you diving a little deeper?
Cutting-Edge Diesel
Newkirk, OK
https://www.facebook.com/matt.kubik/videos/10208196610100011/
:D we still have 700hp on tap with those times according to calculators. Also track was cold and tires were slipping and well as the clutches letting go on that pass. Nothing but excuses I know but I'll get it back together and prove what it can really do!
i wasn't giving you a hard time, just converting for ya. i'm SURE it's gonna be insane when it's dialed. proud of you !
Cutting-Edge Diesel
Newkirk, OK
dammit man!! wtf is going on with that thing?
how did the slip look? spun a bit on launch?
Over 3k ft lbs things have to be perfect to cause the clutches to last. Our shift box has a momentary switch to dump shift prrsssure to reset back to 1st after the burnout. With the momentary switch we weren't bleeding off all the pressure causing a few lbs of pressure to still be in the system and causing the clutches to drag in 1st. We have new 3 way normally closed and open to atmo when closed solinoinds that will fix that issue and they flow more so we have apply faster.
Cutting-Edge Diesel
Newkirk, OK
Thanks man!:thumbsup:
We were going to hit the track today because I rebuilt the Lenco Friday but we are waiting till I get the solinoids in and get everything as perfect as I can. Give us the best odds. Only bad thing is tracks arnt having a test and tune till march 11th
