Finally delivered
Sportchassis06
Well still waiting on a few things.
Window thresholds changed out
Got it taken apart for paint tho.
Eliminating ALL the chrome.
Sent all the lights off to Jeremy at RetroShop.
The cab lights are sealed this go round, so I sent them also.
Still need to swap the chrome tow hooks out and install morimoto led fog lights.
Had the chrome strip in the running board eliminated.
Installed the Pace Edwards bedlocker and a small ford swing box.
The electric bed cover is absolutely great! It has a wireless remote but I also installed a switch on the in bed trailer plug housing.
Forgot to grab a pic of that but I can if someone would like to see it.
Just waiting on King now.
Probably gonna throw on some Bilstein 5100s until they arrive, bc I want to get this thing done.
Went with the 2.5 adjustable Kings all around.
4.5 Carli coils and OUO adjustable leveler up front with an OUO front truss.
OUO 7 inch traction blocks for the rear.
How hard was removal off cab lights?Do they jus lift up,once srew is removed?
Spatel23
Olive Branch, MS
Yes
Remove the screw then slide the light back (towards the bed) the front will be able to pull out easy, then the back will come unclipped.
A small tip screw driver will help undo the wire clip if you've got fat fingers.
The harness is really short
Sportchassis06
Yes
TY!
Spatel23
Olive Branch, MS
Administrator
4.5 plus the leveler which is adjustable and can add from 0 to 2.5 of lift.
Ill be setting it at around 6
ill be running 37s
Im way behind
haha
sure is
hopefully get them on the way soon
good thing i love you unconditionally .
Spatel23
Olive Branch, MS
Some preview pics of the headlights, tail lights, third brake light, and cab lights.
Jeremy at RetroShop did a great job!
and I couldnt wait any longer to see a wheel bolted up
Jgon08
Looks good shone, can't wait for my lift and everything to be on.
