Flexy04
Vancouver BC
quote on superduty V code front springs. B code rear springs. U Bolts front and rear.
New nuts and bolts for the springs also. Thanks!!
eastern
Liberty NY
VIN- HEC59425. I need from ford oem plug on frame to sensors, as well as gromets that will hold sensors. I know I will have to do some fudging to make them work since OEM bumper is curved and I am installing in flat bumper. Utility co. tagged oem plugs on frame for me. 2017 plugs.jpg
sunrisefordparts
VIN- HEC59425. I need from ford oem plug on frame to sensors, as well as gromets that will hold sensors. I know I will have to do some fudging to make them work since OEM bumper is curved and I am installing in flat bumper. Utility co. tagged oem plugs on frame for me.View attachment 46999
well the vin doesn't want to work for me can you shoot me the full vin? sorry for the back and forth.
sunrisefordparts
1FT8W3DT1HEC59425
sensor harness list $27.35 sell $19.69
sensor retainers list $8.05 each sell $5.80 each, possibly the center 2 sensors on the oem bumper have the flattest mounting surface and would work for all locations of the aftermarket bumper.
q#474256
Lugger007
Ct
2012 f250 6.7
-Line from windshield washer fluid tank to each sprayers and spray nozzles on hood
-plastic tail gate cap without step
-fuse box cover for fuse box under hood
-power steering pump, is a rebuild kit available or just replace?
Thank you
jngreen
IN
Just placed an order online. I wasn't sure if I get the same discount but wanted to place the order today anyway to get it on the road tomorrow. I ordered part number 7T4Z-3A713-A. Order 32829462
Thanks,
Josh
107stroker
we offer 25% discount on over the counter parts purchases and online orders to all forum members. and special pricing on filters. you can send us an email at [email protected] or post request here. you also can call 909-822-8736 ask for brittian or kevin.
thanks
Jim Cockerham
parts director
Sunrise Ford fontana and North Hollywood
909-434-0473 xt 2120
Im in the market for a ptm grill for a 2008 f250. what is your price on this and can i get it in an oem color. oxford white. thanks
my contact number is (910)232-7110
griz700rocket
Cisne, IL
2011 F-250 single cab 4x4 without rear helper springs.
Looking to change from the stock 2in leaf spring blocks to the F-350 3 5/8th blocks.
So I'll need the right block, left block and 4 u-bolts to go along with them.
Already have the nuts and everything else.
sunrisefordparts
Thanks,
Josh
sorry didn't see this message till this am, you part is going out today we had to order it in from ford as for the discount you ended up getting a better deal as the website had the pricing way to low.
sunrisefordparts
does your truck have the factory overload spring?
well im an idiot just read back and actually seen that you said no overloads
sunrisefordparts
2012 f250 6.7
Thank you
here ya go
  • q475079.pdf
