Secondary cooling system puking from overflow hose
So I made a catch can for my secondary, being I'll be racing in TX this weekend. I can't have it puke on the track.... I'll be able to see how much comes out now and will keep people posted.
Mounts inside the bumper and out of the way. Also allows for easy draining.
holy chitballz.. what's the next step?
Change the CAC again and see if it fixes it. If it does. I think I need Mikes CAC.
Coming home from CA this Duramax had to die. I won, but at the expense of my CAC lol.
oh chit!! I'd prolly jump right to Mikes cooler and be done..
Probably. I guess bouncing off the speed limiter hurts the CAC.
8WR_ZJ
Lol that's no bueno. Get it fixed soon. Does it puke all the time or only under heavy load/boost?
Heavy load. But CAC doesn't seem to be working. I'm 50-60 degrees higher in my post CAC vs IAT., this is cruising at 85mph outside temp was 55degrees.
So my CACT temps were a bit toasty coming home last night.
Truck won't puke if I drive normal. It's when it's sustained boost (passing on the I10 at WOT) where boost is at 30+ for 10+ seconds. I just see that CACT just climb FAST
Messing with it this weekend and will report back. Might even go buy a new ford CAC.
So you were rougly 1/2 throttle in that picture? What should the cac temps be at temp range wise?
Slight uphill, about half throttle got to about 105mph. Temp should be close to the IAT of 86.
ckrueg
Belding MI
yeah those temps are crazy high. I've never seen more than a 30 degree difference and usually its less than that
