Transmission leaking from bellhousing
matoolis
So i've got a leak. 06 f350 w/ auto, 4x4
Trans is leaking from the bellhousing but only while the truck is in gear from what i can tell, First i tried replacing the pump seal, still leaked. So i pulled the trans back out again and pulled the pump assembly, Disassembled the pump and found the inner gear had a piece broke off from one of the flat spots where the torque converter drives it. so i replaced it, cleaned it all while it was disassembled, and put the pump back in with a new gasket. Still leaks, it leaked about half a quart driving about 45 minutes.
What else could it be?
Thanks!
Lipka101
Maryland
Worn bushing for converter. Too much play so it pushes seal and leaks. Should have checked it while you had it apart.
matoolis
I looked and it didn't look worn and there wasn't any grooves on the converter either.
