So i've got a leak. 06 f350 w/ auto, 4x4
Trans is leaking from the bellhousing but only while the truck is in gear from what i can tell, First i tried replacing the pump seal, still leaked. So i pulled the trans back out again and pulled the pump assembly, Disassembled the pump and found the inner gear had a piece broke off from one of the flat spots where the torque converter drives it. so i replaced it, cleaned it all while it was disassembled, and put the pump back in with a new gasket. Still leaks, it leaked about half a quart driving about 45 minutes.
What else could it be?
Thanks!
Thanks!
