Dirtclod
Oh btw! I’ve ordered 238/80’s from unlimited and hydra with gh custom tunes. And sending off hoop tomorrow to diesel site.
Gotta question for some of y’all. When I pulled the injectors there was a lot of oil in and covering them. That’s the first time I’ve ever done that and was wondering if that’s normal? Also I fixed a small piece of tubing to my shop vac and was told to suck up the oil off the top of the pistons. Well there is quiet a bit oil ther or I’m sucking oil out of the pan. Am I actually pulling oil out of the engine by doing this?
I rotated motor over to tdc and used a might vac with a small tube pushed down through injector cup. The back 2 cylinders had the most oil. The rest where not to bad.
Yep poured oil in the reservoir and thanks for the tip on cranking. I had forgot about that.Your truck will start without the chip no problem. Just don’t try to drive with it...
With that said... you need to connect the chip to your laptop and transfer the tunes over. Then install the chip onto the pcm (batteries unplugged).
Prior to cranking - did you pour oil into the hpop? That will allow you to start the truck faster. Make sure batteries are fully charged. Crank 20sec intervals, minute rest, crank again till it starts.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
I just downloaded it on my laptop and yes they had already loaded it. I’m new to this stuff really. I had a ts 6 pos chip once but it was preloaded. At least now I know how to receive tunes and download them on my chip. I really need to get a obd2 connector and diagnostics app. The only thing that might stop it cranking would be ipr valve. I was going to replace that and the cps but $ got tight. I did take it apart and clean it. Just hope that didn’t mess it up. By cleaning I went over it with some 2000 grit sandpaper.If you have the extension cable, there's no reason to remove the chip for loading tunes. And it depends, if you told them about your mods (if injectors) they could have loaded tunes.
Sent from my SM-G892A using Tapatalk
That might have been a bad idea with the 2000grit. Could have got into ipr and sand, oil, injectors might not be a good mix. I think you’ll be alright.
If the ipr, cps wasn’t problematic prior, you should have no other problems starting up the beast.
—————signature—————
Do you really mean cranking? Or did you mean starting?
Pulled the plug on the drivers side oil rail and had a friend crank it over for 15-20 seconds and just a lil oil coming out.
