Mesa, AZ
2015 cclb pearl plati 4x4 109k miles. Not finalized yet. But put money down on it. Gotta wait for the bank on Wednesday to do all the paperwork. Once i get paid from the insurance company then i should only be a couple grand from payoff..
Congrats on the new truck, ****ty way to get one, but congrats none the less...
mandkole
Northwest
Fixed a water pump neck leak, upper and lower hoses, coolant swap and a needed bath..
C2tuck
North Texas
Dropped it off at the dealer for a suspected primary water pump and CCV replacement. Hope to have it back by Thursday.
greyford1979
Copley,Ohio
Found out that I blew the brake line that runs from the front of the truck all the way to the rear. Lost most of the fluid onto the axle on the way home from work yesterday. Definitely made my butthole pucker going down a steep hill by work and the brake pedal went to the floor. What a wonderful way to start off the new year. Well at least I made it home without crashing into anything. Guess I'm gonna change out the rubber hoses to the stainless braided lines while I'm at it.
Tn
Not a hard job but time consuming to drop the fuel tank and get all the bends just right. Have had to do it twice now on two spectate trucks. Like you said, could have been a lot worse.
greyford1979
Copley,Ohio
Yeah when it happened, first thing I thought was why if it was going to happen, why couldn't it have blown when I had the fuel tank out to do my fuel system lol. Oh well, it's lasted to 317,000 miles, so it had a good run. Now just wondering which one is next to go?
PDT1081
Bowling Green, OH
Cut the old one at each end of the tank and fish a new one through. You can anchor it to the old one, so there's no need to drop the tank.
ToMang07
Mainah!
Had that happen to me while plowing down my driveway.... got to the bottom and nothing. Took a set of vice grips to the end of the line, topped it off, and finished plowing, lol
Sent from my SM-G960U using Tapatalk
greyford1979
Copley,Ohio
Luckily I don't live to far from work and was able to limp it home. I couldn't tell where it was leaking till yesterday because it was raining Monday night on the way home and everything underneath was wet.
dsberman94
Pennsylvania
I had that same line rot through over the summer. Luckily I was just moving firewood around the property. Still hairy when your backup up to the house and the truck won’t stop. I was able to get the old section of line cut out and went to the part store for a replacement section and fittings, hand bent it and got it put back in without too much of a problem.
psduser1
on the road
New pads and rotors on the back of the ex.
Rotated tires, and replaced one wheel seal in the back. Standard maintenance, lol.
Oh yeah, finished pulling another " bulletproof" zf6 out of my 00 flatbed. Bout time to dump that shot for a 4r, lol.
Change my mind----
Change my mind----
Do it!! Just get good custom trans tuning for the 4r. Or shift it manually. Lol
Connor M
Masshole
Pulled the kick panel apart to get my door code because I was bored. Not super hard but I don't fit under the dash. Awkward to get at.
